Switches keep appearing as stacks in CW even when a single unit
Nov 7th, 2007
I have been trying with little success to reset the switch identity type in CiscoWorks from a "Cisco 3750 Stack" to a "Cisco 3750-24ts". Every time it is modified, after a few seconds the type switches back to the "stack" type. I have even tried removing the device(s) and re-adding them to CW but the same thing occurs. The unit is in fact not a stack but a single switch unit. Is this behavior being caused from the unit's IOS? ((C3750-IPBASE-M), Version 12.2(25)SEB1) or is there a configuration item that I have missed that should allow it to appear as a single unit to CW?
David Stanford Wed, 11/07/2007 - 06:47
  • Cisco Employee,
You might want to post this in the Network Management Forum
Nicoleperez Thu, 11/08/2007 - 11:48
In the configuration of the switch do you have switch 2 provision (switch). Perhaps it was stacked at one point and you will have to get rid of the statement of switch 2 in the configurations.
