Tightening access-list
Nov 7th, 2007
I want to tighten my access-lists so that only certain clients can see certain host.
I am running on a PIX 515 ver 7.1(2).4
My current access list is
access-list 111 extended permit ip 10.10.128.0 255.255.255.0 192.9.20.0 255.255.255.0
What I want to do is only allow users on the 192.9.20.0 network to access a server at 10.10.128.33 for telnet application. I also want one user to from the 10.10.128.0 network to access servers on the 192.9.20.0
I put in the following two access-lists
access-list 111 extended permit ip host 10.10.128.183 192.9.20.0 255.255.255.0
access-list 111 extended permit tcp host 10.10.128.33 192.9.20.0 255.255.255.0 eq telnet
Problem is that I can not connect to the 10.10.128.33 server via telnet anymore from the 192.9.20.0 network.
Also, even though I can still RDC into a server from 10.10.128.0 network that is on teh 192.9.20.0 network it continuous drops the connection and then reesablishes. This never happened with the previous access-list.
Any help is appreciated.
Thanks.
Jon Marshall Wed, 11/07/2007 - 07:35
The telnet line in your access-list needs changing
access-list 111 extended permit tcp 192.9.20.0 255.255.255.0 host 10.10.128.33 eq telnet
Jon
boschrexroth Wed, 11/07/2007 - 08:59
Hi Jon,
Thanks but this access-list didn't work either.
Just so you know the PIX is on the 10.10.128.0 network and the 192.9.20.0 is a remote network that is using a VPN tunnel to connect.
Any other thoughts.
Thanks.
Jon Marshall Thu, 11/08/2007 - 12:13
Sorry, i missed your original reply.
Can you post configs if you have them for both ends of the VPN tunnel ?
Jon
