11-07-2007 06:50 AM - edited 07-03-2021 02:53 PM
I want to use 2 1310 APs as trunk links between switches. I have 1 set as root-bridge and the other as non-root. The non-root stays in the reset state on the dot11radio0 and does not connect. What causes it to go into that state??
I have configured an SSID for each vlan I want to pass and an infrastucture ssid.
The switchports the APs are connected to are set as trunk ports that will pass all vlans.
If there is anyone with a config for this or has done it before would really help.
John M.
11-09-2007 08:07 AM
The nonroot radio will stay down (even if it's enabled) until it can associate with the root bridge. I would remove all security and the VLANs to leave just one SSID then build the config back up again one step at a time.
11-14-2007 12:14 PM
Thanks for the input...
The radio will also stay in reset mode if it does not have an antenna attached.....We ordered the wrong p/n!!!! I now have connectivity with the internal antennas!! seems to be working well. Just a dhcp issue now.
11-14-2007 12:36 PM
Aha! Not having an antenna is a bit of an issue! : ) Glad you got it figured out.
