Access List
Answered Question
Nov 7th, 2007
We have access list and it is over 100 commands. can we have simple way to remove one access list of them? or add one access list in between them, (not at the end of the whole ACL)?
Thank you
Correct Answer by keller.oliver about 9 years 6 months ago
Oldschool : Work with an editor
Just edit some textfile offline and then paste it to the session you have with the machine.
For example if you have ACL 101, then the text would look like :
! clear the existing ACL 101
no access-list 101
! new ACL rules 101
access-list 101 permit x
access-list 101 permit y
access-list 101 deny z
END
If you're in config mode and transfer that, the existing ACL is cleared and instantly filled with the new rules. Plus, it's more convenient to do cut, copy and paste in an external editor compared to even named ACLs, so you have a better view on what you're doing.
Just my two cent ;)
Beware :
Extended IP ACL : access-list [nr] ....
Named IP ACL : ip access-list extended [name]
It's easy to forget the "ip" when you're too familiar with the "numbered ACL" version ;)
Correct Answer by Edison Ortiz about 9 years 6 months ago
Yes, you can use named ACLs instead of numbered ACLs.
Example,
Rack1R2#sh run | sec ip access
ip access-list extended anita
permit ip any 192.168.1.0 0.0.0.255
permit ip any 192.168.2.0 0.0.0.255
permit ip any 192.168.3.0 0.0.0.255
permit ip any 192.168.4.0 0.0.0.255
Now, let's say I want to have any entry between 192.168.3.0 and 192.168.4.0
Rack1R2#show ip acces
Extended IP access list anita
10 permit ip any 192.168.1.0 0.0.0.255
20 permit ip any 192.168.2.0 0.0.0.255
30 permit ip any 192.168.3.0 0.0.0.255
40 permit ip any 192.168.4.0 0.0.0.255
Rack1R2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1R2(config)#ip access-list extended anita
Rack1R2(config-ext-nacl)#35 deny ip any 192.168.4.0 0.0.0.31
Rack1R2(config-ext-nacl)#do show ip acce
Overall Rating: 5 (4 ratings)
Correct Answer
Edison Ortiz Wed, 11/07/2007 - 07:55
  • Hall of Fame,
    Founding Member
Example,
Rack1R2#conf t
Correct Answer
keller.oliver Thu, 11/08/2007 - 04:58
no access-list 101
! new ACL rules 101
END
Just my two cent ;)
Beware :
