ccme problems with calls among ip phones and remote analog phones
Nov 7th, 2007
I have a CCME (I am using IP phones and analog phones) using dial peers to communicate to a remote office that only has analog phones (it uses a router as a gateway) the calls done from an analog phone to an analog phone in the remote site work properly but calls done from an IP phone to an analog phone in the remote site does not work, what happens is that the ring is heard but no voice can be heard
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 11/07/2007 - 08:48
  • Hall of Fame,
    Founding Member
Do you have any Firewall, NAT, or VPN between the CCME router and the remote gateway ?
paolo bevilacqua Wed, 11/07/2007 - 09:35
  • Hall of Fame,
    Founding Member
Please send telephony-related config for both routers.
mauricebar Wed, 11/07/2007 - 12:40
ROUTER REMOTE
voice-port 0/0/0
timeouts call-disconnect 6
timeouts wait-release 6
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 30 voip
destination-pattern 3.
session target ipv4:10.210.0.2
req-qos controlled-load
codec g723ar63
dial-peer voice 50 voip
destination-pattern 5.
session target ipv4:172.17.2.14
req-qos guaranteed-delay
codec g723ar63
dial-peer voice 60 voip
destination-pattern 60
session target ipv4:172.17.2.254
codec g723ar63
dial-peer voice 70 voip
destination-pattern 70
session target ipv4:172.17.2.38
codec g723ar63
dial-peer voice 71 voip
destination-pattern 71
codec g723ar63
dial-peer voice 72 voip
destination-pattern 72
session target ipv4:10.210.0.6
codec g723ar63
dial-peer voice 73 voip
destination-pattern 73
codec g723ar63
dial-peer voice 80 voip
destination-pattern 8.
session target ipv4:172.17.2.10
codec g723ar63
dial-peer voice 400 voip
destination-pattern 4..
session target ipv4:172.17.2.26
codec g723ar63
dial-peer voice 100 pots
destination-pattern 1..
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 102 pots
port 0/2/2
dial-peer voice 103 pots
port 0/2/3
dial-peer voice 200 pots
destination-pattern 2..
port 0/2/0
dial-peer voice 201 pots
port 0/2/1
dial-peer voice 202 pots
port 0/2/2
dial-peer voice 203 pots
port 0/2/3
dial-peer voice 104 pots
port 0/0/0
dial-peer voice 105 pots
port 0/0/1
dial-peer voice 204 pots
port 0/0/0
dial-peer voice 205 pots
port 0/0/1
dial-peer voice 90 voip
destination-pattern 43.
session target ipv4:10.210.0.10
codec g723ar63
dial-peer voice 61 voip
destination-pattern 61
codec g723ar63
dial-peer voice 62 voip
destination-pattern 62
session target ipv4:10.210.0.22
codec g723ar63
dial-peer voice 63 voip
destination-pattern 63
codec g723ar63
dial-peer voice 106 pots
port 0/0/2
dial-peer voice 107 pots
port 0/0/3
dial-peer voice 206 pots
port 0/0/2
dial-peer voice 207 pots
port 0/0/3
num-exp 1.. 11..
num-exp 2.. 22..
banner motd
Ahi si dale con Fe!
mauricebar Wed, 11/07/2007 - 12:42
ROUTER HQ
voip-incoming translation-profile TEST
fax interface-type fax-mail
voice-port 2/0
voice-port 2/1
voice-port 3/0
voice-port 3/1
dial-peer cor custom
dial-peer voice 100 voip
codec g723ar63
dial-peer voice 200 voip
codec g723ar63
codec g723ar63
dial-peer voice 430 voip
session target ipv4:10.10.20.247
codec g723ar63
dial-peer voice 400 pots
destination-pattern 40.
port 2/0
dial-peer voice 401 pots
port 2/1
dial-peer voice 402 pots
port 3/0
dial-peer voice 403 pots
port 3/1
dial-peer voice 410 pots
destination-pattern 41.
port 2/0
dial-peer voice 411 pots
port 2/1
dial-peer voice 412 pots
port 3/0
dial-peer voice 413 pots
port 3/1
telephony-service
max-ephones 20
max-dn 20
ip source-address 10.10.11.10 port 2000
auto assign 1 to 20
system message Garda Export ITS
user-locale ES
user-locale 1 ES
user-locale 2 ES
user-locale 3 ES
user-locale 4 ES
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Oct 23 2007 15:16:17
ephone-dn 1 dual-line
number 450
name Vladimir Witt
ephone-dn 2 dual-line
number 451
name Oscar Teran
ephone-dn 3 dual-line
number 452
name Rodrigo Achinia
ephone-dn 4 dual-line
number 453
name Wilman Tapia
ephone-dn 5 dual-line
number 454
name Wilian Cortez
ephone-dn 6 dual-line
number 455
name Enrique Cachipuendo
ephone-dn 7 dual-line
number 456
name Felix Farinango
ephone-dn 8 dual-line
number 457
name Marta Guania
ephone-dn 9 dual-line
number 458
name Eduardo Herrera
ephone-dn 10 dual-line
number 459
name Hector Ayala
ephone-dn 11 dual-line
number 460
ephone-dn 12 dual-line
number 461
ephone-dn 13 dual-line
number 462
ephone-dn 14 dual-line
number 463
ephone-dn 15 dual-line
number 464
ephone-dn 16 dual-line
number 465
ephone-dn 17 dual-line
number 466
ephone-dn 18 dual-line
number 467
ephone-dn 19 dual-line
number 468
ephone-dn 20 dual-line
number 469
ephone 1
no multicast-moh
mac-address 001D.451B.9E4C
codec g729r8
type 7921
button 1:1
ephone 2
no multicast-moh
mac-address 001D.451B.A8A8
codec g729r8
type 7921
button 1:2
ephone 3
no multicast-moh
mac-address 001D.451B.9F15
codec g729r8
type 7921
button 1:3
ephone 4
no multicast-moh
mac-address 001C.58CD.5A0F
codec g729r8
type 7921
button 1:4
ephone 5
no multicast-moh
mac-address 001D.451B.9D2F
codec g729r8
type 7921
button 1:5
ephone 6
no multicast-moh
mac-address 001D.451B.A5AB
codec g729r8
type 7921
button 1:6
ephone 7
no multicast-moh
mac-address 001D.451B.A7DC
codec g729r8
type 7921
button 1:7
ephone 8
no multicast-moh
mac-address 001C.58CD.5031
codec g729r8
type 7921
button 1:8
ephone 9
no multicast-moh
mac-address 001C.58CD.4EDE
codec g729r8
type 7921
button 1:9
ephone 10
no multicast-moh
mac-address 001D.451B.9D9B
codec g729r8
type 7921
button 1:10
THE ONLY OTHER THING USED IS GRE TUNNELS TO PASS THE VOICE.
paolo bevilacqua Wed, 11/07/2007 - 12:54
  • Hall of Fame,
    Founding Member
You can't mix and match codecs.
On the remote router, you need to configure an incoming DP with a fixed codec, or a voice-class.
For call originated by IP phones, you have only two choices, g711u (default) or g729 (that you have configured for some ephones).
Conversely for call from remote site to IP phones.
dial-peer voice 999 voip
incoming called-number 4..
codec g711
mauricebar Wed, 11/14/2007 - 10:18
Hi actually I have tested using the incoming-called number command using the pattern 4.. and specifying the g729r8 codec, but it is still the same, the phone rings and when answring no voice is heard.
paolo bevilacqua Wed, 11/14/2007 - 10:31
  • Hall of Fame,
    Founding Member
I still think it can be a codec issue, can try placing "protocol sipv2" on the outgoing voip DP, enable "term mon" and "debug ccsip message", palce the call, sends result here.
mauricebar Wed, 11/14/2007 - 11:55
I don't have that command available on the Voip dial-peer.
I have c2801-spservicesk9-mz.123-11.T5.bin on the one side and c1700-ipvoicek9-mz.124-15.T.bin in the other side, do you think it's IOS?
mauricebar Wed, 11/14/2007 - 12:15
Sorry, I found the command, the output is:
Nov 14 15:11:40: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.2.26:5060;branch=z9hG4bK0E1C
Remote-Party-ID: "Wilman Tapia" ;party=calling;screen=no;privacy=off
To:
Date: Wed, 14 Nov 2007 20:11:40 GMT
Call-ID: [email protected]
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 2769350037-2451837404-2164447273-3995059350
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1195071100
Contact:
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 3659 3465 IN IP4 172.17.2.26
s=SIP Call
c=IN IP4 172.17.2.26
t=0 0
m=audio 18732 RTP/AVP 4 19
a=rtpmap:4 G723/8000
a=fmtp:4 bitrate=6.3;annexa=yes
a=rtpmap:19 CN/8000
a=ptime:30
paolo bevilacqua Wed, 11/14/2007 - 12:43
  • Hall of Fame,
    Founding Member
do you get this only ? If you never get an "received" message, it means that the remote gateway either is not getting the invite, or the reply back is lost.
Are 172.17.2.25 and the addresses on the GRE tunnel?
mauricebar Sat, 11/17/2007 - 19:56
Yes those IPs are in the GRE tunnel. Actually I have changed all codecs to g79r8 and now it works properly. I know it is a codec problem, the transcoding from g723 to g729 but I really don't get how to fix it.
paolo bevilacqua Sun, 11/18/2007 - 02:01
  • Hall of Fame,
    Founding Member
You can try "universal transcodig" in 12.4(11)XW4:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a008076161a.html
I suggest you would use G.711u local, and iLBC on the WAN. G.723 is not dsigned for packet networks and has poor voice quality.
mauricebar Mon, 11/19/2007 - 13:02
Hi very interesting this, maybe am going to try it later. By now everything is working with g729r8.
Thank you very much for your assistance.
Mauricio
paolo bevilacqua Mon, 11/19/2007 - 13:08
  • Hall of Fame,
    Founding Member
You are very welcome. Please remember to rate useful post with the scrollbox below!
