No EIGRP neighbor on Layer 3 port
Nov 7th, 2007
After "switchport" was removed on the 6509 Gig 1/1 port, I then assign an IP address to it as well as the other end of the cable which is an 2821 router to use it as a Layer 3 ports. I can Ping across the interfaces but they can't establish EIGRP neighbor. Any ideas what I am doing wrong?
Edison Ortiz Wed, 11/07/2007 - 08:49
  • Hall of Fame,
    Founding Member
Is the new IP address included in the eigrp process ?
Can we see the show ip eigrp int output from both devices ?
glen.grant Wed, 11/07/2007 - 08:50
  • Purple, 4500 points or more
Did you add your network statement for the link under the eigrp process.
nguyenvinnie Wed, 11/07/2007 - 09:55
Thanks for quick responds from you and EdisonOrtiz that point me to the right direction .
I had a bad mask in EIGRP statement, things are looking great now.
