Removing Specific Settings on Phone
Nov 7th, 2007
Ok when I push the settings button on a Cisco phone, and choose Network Configuration, I can see all kinds of information (IP address, TFTP Server, Default Gateway, etc). I want my users to be able to access the network configuration but I want to pick in choose what they can see.
For example, I want to remove the IP Address field from showing up. How can I do that? Edit a jsp, xml, or asp file, etc? I'm pretty sure there is no option to just pick and choose and I'm willing to go into the code of CallManager in order to make it happen. The particular version I'm working with is CM 4.2(3).
