CW Topology services map - Unconnected devices
Nov 7th, 2007
does any one know if it is possible to manually add links to devoces that do not have cdp enabled?
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/07/2007 - 09:20
This is not possible. You can, however, export the map to Visio, then draw a more complete topology there.
ogormam2 Wed, 11/07/2007 - 09:22
Thanks very much for your response
but that is not good, what about PIX firewalls will they only show up as unconnected devices?
Joe Clarke Wed, 11/07/2007 - 09:24
Correct. PIX, ASA, and FWSM devices are not supported by Campus Manager since they do not support CDP.
ogormam2 Wed, 11/07/2007 - 09:27
Hi Joe,
thanks very much for your help.
I had just spent the last hour trying to find this information on the Cisco website.
I have to say im not impressed.
manishdshah28 Tue, 10/28/2008 - 19:22
This is really a big pain and a bottleneck with LMS platform. Cisco should do something to support these Cisco devices or add it manually and gte SNMP managed. Why should one not have a whole network view when everything is Cisco, I am not convinced.
bevan.barry Thu, 11/06/2008 - 10:21
Hi guys,
I'm new to LMS but was wondering if it has a dynamic view of the topology? So if I were to power off a device or disconnect a link, will this be reflected dynamically in the topology map? I've gotten email alerting to work fine though. Is this at all possible?
