natting on firewall
Nov 7th, 2007
Hi all, can anyone tell me the command for natting to the outside interface address for all my internal users internet access, i know on my router its ip nat inside source list 1 interface dialler1 overload.
what is the command on the asa for this ?
thanks
Overall Rating: 3 (1 ratings)
Jon Marshall Wed, 11/07/2007 - 12:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Carl
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
Assuming you have called the inside interface "inside" and the outside interface "outside".
Jon
Jon Marshall Thu, 11/08/2007 - 02:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The global command is needed to tie it to the relevant NAT command ie
says NAT all addresses ariiving on the inside interface BUT it doesn't tell you what you want to NAT it to. That is what the global command does
Notice the same index number (1) has been used in the nat and global statements.
Jon
carl_townshend Thu, 11/08/2007 - 08:57
can you explain a little more on the global command and the outside command ? ie do you need to specify the outside interface name ie outside interface eth1 ?
Jon Marshall Thu, 11/08/2007 - 12:09
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Carl
Sorry i missed this before.
To answer your first question. To create a static translation
static (inside,outside) 217.75.10.2 192.168.5.1 netmask 255.255.255.255
means - present the internal address of 192.168.5.1 as 217.75.10.2 to the outside of the pix.
As for the global command
global (outside) 1 217.66.10.5
means Nat all internal address to the ip address 217.66.10.5
using the command
is just shorthand really to say NAT all inside addresses to the address of the pix outside interface. You don't need to use the actual physical interface name ie. eth1 because the pix/asa device refers to the eth1 interface as "outside".
Hope this makes sense
Jon
