ATA and strobe lights
Nov 7th, 2007
I know we can connect up a strobe light for a hard-of-hearing user that lights a light. On the back of the ATA-186 there ar 2-ports for analog phones that the light can plug into, if we plug 2 lights into the 2 ports will they both light up when a call comes in or would just one?
Thanks.
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 11/07/2007 - 11:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
Hope things are going well for you :) The second Jack is generally used for a second phone Line/Extension. You could probably set them both up for the same number, but depending on the distance between the Strobe and the ATA you might alos be able to just use a "T" Line Splitter. The strobe probably has a REN (Ringer Equivilancy(sp?) Number) that will determine whether or not the one line can power two Strobes. Either way you win!
5 REN 200 feet (61 m)
4 REN 1000 feet (305 m)
3 REN 1700 feet (518 m)
2 REN 2500 feet (762 m)
1 REN 3200 feet (975 m)
From this good doc;
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a00800c4d1c.html#1034692
Hope this helps!
Rob
j.mccartney Wed, 11/07/2007 - 11:53
Thanks as usual Rob; that is what I was thinking that a splitter may have to be involved.
John
