IP's dont work
ptlane123
I was given a block of IP's [six usable]and wanted to test out RDP. I added these commands to our ASA 5510 FW:
access-list inbound extended permit tcp any host 72.164.1xx.xx eq 3389
static (inside,outside) 72.164.1xx.xx 192.168.2.4 netmask 255.255.255.255
What happens is that not only can't I connect to the 192.168.2.4 with RDP, I can't browse out to the internet from the 192.168.2.4 IP. Am I missing a command?
JORGE RODRIGUEZ
Level 10
Level 10
Paul, could you post asa config. For your inside hosts to go out internet you need couple of statement in your firewall.
e.g.
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
this should allow your inside get outbound access to internet.
as for your new IP block, make sure RDP is enable on the machine and that no firewall is neither enable if it is an XP machine.
access list should be something like this:
e.g
your static NAT is ok.
access-list outside_access_in permit tcp any host 72.164.x.x eq 3389
access-group outside_access_in in interface outside
Jorge
Jorge Rodriguez
