Move nameif to another interface
Nov 7th, 2007
Is there an easy way to move the configuration from one interface to another. I want to move "nameif dmz" from eth2 to eth3 and in the past once I removed or renamed the original interface the pix would remove or rename the config for that nameif. I hope this makes sense.
Overall Rating: 3 (1 ratings)
Richard Burts Thu, 11/08/2007 - 06:59
I am not aware of any way to have the PIX transfer the dmz configuration from one interface to another. If it were me I would do show run, then copy and paste the config statements relative to dmz into a text file. Then in the text file I would prepare "no ..." statements to remove dmz from eth2 and change the config statements for dmz to eth3. Then go into config mode and cut and paste the commands from the text file into the config.
