Accessing Router from WAN-Side (Internet)
Nov 7th, 2007
Hi !
I have a little issue with my C871 box. I would like to access the routers
management console through ssh & https (SDM) from the Internet.
At the moment this does not work. I am able to ping the device but I am not
able to access the box through ssh or https although I opened the FW on the
Box.
Maybe somebody can check my attached config?
Thanx....Andy
Richard Burts Wed, 11/07/2007 - 13:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
The cause of your problems can be found in the config that you posted. As for the access via HTTPS look at these lines:
ip http access-class 2
ip http authentication local
ip http secure-server
This says that access via HTTPS must be permitted by access list 2 which permits only the addresses of VLAN 1 to access it and denies any other access:
access-list 2 remark HTTP Access-class list
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny any
The SSH issues is in the config of the vty lines. You do have them configured so that they accept SSH but not telnet. But you have put an access restriction on the vty lines with this:
line vty 0 4
access-class 23 in
which says that any SSH access must be permitted by access list 23. But there is no access list 23.
So to permit HTTPS you would need to add your source address to access list 2. And to permit SSH you must create access list 23 and it must permit your source address.
Rick
