Clientless SSL VPN
Nov 7th, 2007
I am not sure if this is what I would like. I am looking for a way for a client to connect to our network via SSL VPN. My goal is to do this clientless and once they have authenticated, I would prefer for them to have a log off method, but I would like for them to be able to access the network as if they were sitting at their desktops here at work. I do not want to limit their access since that has already been somewhat completed.
Is the client SSL VPN the way I should go or can some recommend another method? I am trying to do away with the Cisco VPN client as much as possible and connect to our ASA 5520.
Is there a good example for setting this up?
Thanks for all your advice.
Dwane
