Converting crypto map to unnumbered VTI
Nov 7th, 2007
I'm trying to convert a crypto map VPN to a ip unnumbered VTI. The crypto map has been working for months. The VTI... no so much. Here are the applicable config entries.
### original config
crypto isakmp policy 30
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxxxxx address 10.1.1.10
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map CRYPTO 50 ipsec-isakmp
set peer 10.1.1.10
set transform-set 3DES-SHA
set pfs group2
match address VPN1
ip access-list extended VPN1
permit ip host 172.16.16.10 host 10.5.5.1
permit ip host 172.16.16.10 host 10.5.5.4
I only removed the crypto map and added the following.
### New Config
crypto ipsec profile V1
set security-association lifetime seconds 28800
set pfs group2
interface Tunnel0
ip unnumbered FastEthernet0/0
ip nat outside
ip virtual-reassembly
tunnel source 172.16.8.1
tunnel destination 10.1.1.10
tunnel mode ipsec ipv4
tunnel protection ipsec profile V1
I keep getting this ISAKMP error now.
ISAKMP:(0:54:HW:2):deleting SA reason "Recevied fatal informational" state (I) QM_IDLE (peer 10.1.1.10)
Any help would be greatly appreciated. Also... I have no idea what is running on the other end (it's a partner network), but I suspect it's a crypto map on IOS.
Thank you!
