Bundleing and redundancy
Nov 7th, 2007
Dear All,
I need some suggestions on one of the scenario we are facing here.
I am maintaining a site which is connected to a central site with a 4 mbps metro Ethernet connectivity.Since this is single link is a single point of failure , we are looking for alternate links (metro Ethernet only) which provides bundling , as well as it should not create a single point of failure. ( i mean both links terminates on two seperate links on both sides(location)
Waiting for ur suggestions
Thanks and regards
dabance
paolo bevilacqua Thu, 11/08/2007 - 02:39
  • Hall of Fame,
    Founding Member
Basically, once you configure a routing protocol over the circuits, that will give you redundancy and load sharing.
