11-07-2007 06:38 PM - edited 03-15-2019 07:07 AM
I have a gateway that can dial any area code with the exception of 502. When dialing 502 I get "The number you have dialed is not a working number" Below are the debugs from calling a non-working 502 number and a working 770 number. Worth noting that I have a gateway in the 502 as well.
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x453FFEC0; count=1
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x453FFEC0; count=0
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x453FFEC0; count=1
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_dp_translate: No profile found in peer 101 for outgoing direction
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_dp_translate: calling_number=2235 calling_octet=0x1
called_number=915025576000 called_octet=0xA1
redirect_number= redirect_type=-1 redirect_plan=-1 redirect_PI=-1 redirect_SI=-1
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
*Nov 8 02:32:13.421: //-1/001E96C01200/RXRULE/regxrule_vp_translate: calling_number=2235 calling_octet=0x1
redirect_number= redirect_type=4294967295 redirect_plan=4294967295
*Nov 8 02:32:18.257: //-1/001E96C01200/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x453FFEC0; count=2
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x454002B0; count=1
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x454002B0; count=0
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x454002B0; count=1
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_dp_translate: No profile found in peer 101 for outgoing direction
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_dp_translate: calling_number=2235 calling_octet=0x1
called_number=917707231011 called_octet=0xA1
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
*Nov 8 02:33:12.585: //-1/006459E41400/RXRULE/regxrule_vp_translate: calling_number=2235 calling_octet=0x1
*Nov 8 02:33:41.069: //-1/006459E41400/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x454002B0; count=2
11-14-2007 12:49 PM
the following lines shows "calling_number=2235 calling_octet=0x1 called_number=915025576000 called_octet=0xA1", the calling is hitting the gateway. It may be a PSTN side problem.
