can not access webserver from inside lan however accessible from outside
Nov 7th, 2007
after installing cisco 1811w nat and pat is working fine from outside and inside just one thing is not working i can not access our webserver through FQN i can access it by the private ip only. it is also solved by modyfing the host file but this does not make any sens as i have to do this on all pcs...what is on the router that preventing the name reslove or what is going on.thanks
Overall Rating: 1 (1 ratings)
lgijssel Wed, 11/07/2007 - 22:39
NAT is designed to operate only on packets that traverse both a nat-inside and a nat-outside interface. This is appearently not the case for your internal traffic.
regards,
Leo
