Subsription Limit exceeded
Nov 7th, 2007
I m using 4215. Its working fine except one problem which happens sometimes but after reloading IPS it again starts working fine.
Problem is:
When i start EventViewer, sometimes it gives me an error
"Error:env:Sender-sd:errLimitExceeded- This subsription cannot be opened because the maximum number of subscriptions are already open"
and a cross sign comes next to added IPS in IEV.
let me know where i m making mistake.
Abid Gorsi
jsivulka Wed, 11/14/2007 - 13:02
13003.0 alert from the sensor causes IEV to start new SDEE subscription. For that you have to disable every 13000 level signatures. And also It affects version 6.0(1)E1. If that is the version that you are running, an upgrade to a
later Service Pack will solve the issue.
