Cisco3845-CCME/K9
Answered Question
Nov 7th, 2007
Good day, my company has a new CCME3845. The question is, what is the command guide to verify the FL-CCME-240 Feat License and if it has a CUE-LANG-ENU enable. Thanks and hoping your reply ASAP.
Correct Answer by Paolo Bevilacqua about 9 years 2 months ago
since these are not tangible items but paper licenses only, there is no command on the router, and you can only check invoices for that.
The 3845 will support 240 phones in any case.
The CUE ships with a preloaded language, that however you can replace if you have access to customer-level CCO downloads.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Thu, 11/08/2007 - 01:08
