ASA and manul certificate install for VPN
Nov 8th, 2007
We are about install VPN with digital cert authentication with our partner..
CA is provided by partner and we need manually install their certificate...
What are steps - I guess we need create PKCS #10 request.. I havent found any guide how to do this can you help me??? Than send this request to partner an he sends back certificate am I correct??? Do you have link for cinfiguration guide??
T.
pszczola1 Sun, 11/11/2007 - 20:53
I would recommend to read;
Cisco ASA all in one: Firewall IPS and VPN
by Jazib Frahim and Omar Santos
as far as I remember the steps are following
1.Generate a key (crypto key generate rsa modulus 1024 (you need domain name defined for the key )
2.configure a trustpoint
crypto ca trustpoint NAME
3.Import CA certificate manually
crypto ca authenticate NAME
(paste the CA certificate)
4.Generate the request for Certification Authority
crypto ca enroll NAME
5.Copy output and send to Certification authority
6.After the CA return the issued certificate
crypto ca import NAME
hope it helps
