Local Director 417
Nov 8th, 2007
I am trying to place local Director to load balance for 8 terminal servers.
The network setup is like this.
VLAN 10 - 192.168.1.x / 24
Cisco 3550 - Fa0/0 -------------à user Network
Cisco 3550 - Fa0/1 -----------à Local Director (User Facing Interface)
VLAN 20 - 192.168.2.x /24
Cisco 3550 - Fa0/10 ----------------à Local Director (Server Facing interface)
Cisco 3550 - Fa0/11 ---------------à Server1
Cisco 3550 - Fa0/19 ----------------à Server8
Virtual IP : 192.168.2.10
Config
: Saved
: LocalDirector 417 Version 4.2.1
syslog output 20.3
no syslog console
enable password 000000000000000000000000000000 encrypted
hostname LocalDirector
no shutdown ethernet 0
no shutdown ethernet 1
no shutdown ethernet 2
shutdown ethernet 3
shutdown ethernet 4
shutdown ethernet 5
interface ethernet 0 auto
interface ethernet 1 auto
interface ethernet 2 auto
interface ethernet 3 auto
interface ethernet 4 auto
interface ethernet 5 auto
mtu 0 1500
mtu 1 1500
mtu 2 1500
mtu 3 1500
mtu 4 1500
mtu 5 1500
multiring all
no secure 0
no secure 1
no secure 2
no secure 3
no secure 4
no secure 5
ping-allow 0
ping-allow 1
ping-allow 2
no ping-allow 3
no ping-allow 4
no ping-allow 5
ip address 192.168.2.100 255.255.255.0
arp timeout 30
no rip passive
rip version 1
failover ip address 0.0.0.0
no failover
failover hellotime 30
password xxxxxxxxxxxxxxxxxxxxxx encrypted
telnet 192.168.0.0 255.255.0.0
snmp-server enable traps
snmp-server community public
no snmp-server contact
no snmp-server location
virtual 192.168.2.10:0:0:tcp is
real 192.168.2.11:0:0:tcp is
real 192.168.2.12:0:0:tcp is
name 192.168.2.10 Virt
name 192.168.2.12 Serv1
name 192.168.2.11 Serv2
no names
bind 192.168.2.10:23:0:tcp 192.168.2.11:23:0:tcp
bind 192.168.2.10:23:0:tcp 192.168.2.12:23:0:tcp
I can ping the virtual IP from user desk but unable to connec to the server..as well as I can connec the server with its real ip..... :(
Please advise what is the wrong on this...config.
Thanks in adv
cisconoval Thu, 11/08/2007 - 07:52
Hi Gurus,
Can someone please help me on this its urgent...
cisconoval Fri, 11/09/2007 - 00:50
I am surprised that no one is there to help me to fix the local director issue..?!?!!!
b-ulrich Fri, 11/09/2007 - 07:12
  • Bronze, 100 points or more
Have you tried using port numbers, say 443, 80, or 23 in the configs (virtual, real, and bind) depending on how you are trying to connect?
cisconoval Fri, 11/09/2007 - 07:31
Thanks for your reply.
Yes, I tried it for port 23...but unsuccessful.... in place of Server I used a router (assigned only IP address & Default route to its ethernet interface. no other config on that)
b-ulrich Fri, 11/09/2007 - 08:07
Have you tried something like this:
route 0.0.0.0 0.0.0.0 192.168.x.x
virtual 192.168.2.10:23:0:tcp is
real 192.168.2.11:23:0:tcp is
chrihussey Tue, 11/13/2007 - 08:05
  • Silver, 250 points or more
I've only touched the Local Director a few times but I think you need to consider the following:
1- The Local Director is a bridge. Having the user facing interface in VLAN10 and in network 192.168.1.0, and the server interface in VLAN 20 and in network 192.168.2.0 seems like there may be a conflict there. Consider having the user interface and server interface in the same VLAN.
2- Again, the Local Director acts like a bridge. Having both interfaces of the LD on the same switch and acting as a bridge between the users and the servers will probably not work. Consider having the LD user interface attached to the network switch and then a separate switch just for the servers attach to the other interface of the LD. All traffic to and from the servers will then have to pass through the LD.
Hope this helps
