SSL Web VPN with the Cisco ASA
asmith1972
Hi we have a cisco ASA 5520 and setup web vpn with secure desktop. We have it setup so that it only lets people login if there machines meet certain settinsg eg Firewall must be on, AV has to be install and up-to-date.
This works however, if a users machine doesn't meet these requirements then they just get a message saying "Your machine doesn't meet the security requirements" The problem is when they call up IT we don't seam to be able to find a log anywhere in the ASA that tells us what bit of the security requirements they failed on.
Does anyone know if there is a option we can tick that will allow us to do this?
ebreniz
Level 6
Level 6
In any case the SSL Web VPN function is not supported on the ASA,
You have to clear webvpn cache and disable and enable it again.
Like so: webvpn
cache
disable
no cache-compressed enable
no disable
