Memory leaks in IP Communicator
Nov 8th, 2007
We've had our CCME/CUE installation running for a couple of months now, but I've noticed that all the IP Communicator clients we have (on 2k sp4 & xp sp2) are all consuming a substantial amount of memory.
They start of OK, around 55-60MB consumed (as shown in the VM size column, not "Mem Usage" on task manager). As time goes on, this creeps up. It's not unusual for me to find it running up at 600+MB over 24 hours. Can other users confirm this, or shed light on to why this might be the case ?
FWIW, I've disabled the "Enable Logging" feature where I've found it turned on, and we're using IPC 2.1.1, CCME 4.1 on IOS 12.4(11)T, on a 2851ISR.
Any suggestions or comments appreciated
Simon Delicata
sadbulali Wed, 11/14/2007 - 13:47
  • Bronze, 100 points or more
Workaround
If this problem is adversely affecting SoftPhone use, close and restart SoftPhone. If whole system is sluggish, an reboot should be done
