CCNP Exam Questions... Help Required
Nov 8th, 2007
Please help me with the following questions.
1) You have noticed a large number of topology changes in the Rapid
Spanning Tree Protocol network. Which statement is true about RSTP topology
changes?
A. Only nonedge ports moving to the blocking state generate a TC BPDU.
B. Any loss of connectivity generates a TC BPDU.
C. Any change in the state of the port generates a TC BPDU.
D. Only nonedge ports moving to the forwarding state generate a TC BPDU.
E. If either an edge port or a nonedge port moves to a block state, then a TC BPDU is
generated.
F. None of the above.
2) A change in the spanning tree network is being propagated to all STP
devices. How are STP timers and state transitions affected when a topology change
occurs in an STP environment?
A. All ports will temporarily transition to the learning state for a period equal to the max
age timer plus the forward delay interval.
B. The default hello time for configuration BDPUs will be reduced for the period of the
max age timer.
C. The default aging time for MAC address entries will be reduced for a period of the
max age timer plus the forward delay interval.
D. All ports will transition temporarily to the learning state for a period equal to the
E. None of the above.
3) What is the purpose of MST, according to the IEEE 802.1s standard?
A. It is the spanning-tree implementation used by non-Cisco 802.1Q switches.
B. It runs a separate instance of STP for each VLAN.
C. It allows a VLAN bridge to use multiple spanning trees to prevent Layer 2 loops.
D. It creates a single loop-tree structure that spans the entire Layer 2 network.
4) A Company uses MSTP within their switched LAN. What is the main purpose of
Multiple Instance Spanning Tree Protocol (MSTP)?
A. To enhance Spanning Tree troubleshooting on multilayer switches
B. To reduce the total number of spanning tree instances necessary for a particular
topology
C. To provide faster convergence when topology changes occur in a switched network
D. To provide protection for STP when a link is unidirectional and BPDUs are being sent
but not received
5) The following was configured on a Host switch:
Host(config) # spanning-tree portfast bpdufilter default
What is the effect of this configuration command?
A. If BPDUs are received by a port configured for PortFast, they are ignored and none are
sent.
B. The command will enable BPDU filtering on all ports regardless of whether they are
configured for BPDU filtering at the interface level.
C. If BPDUs are received by a port configured for Portfast, the port will transition to
forwarding state.
D. If BPDUs are received by a port configured for PortFast, then PortFast is disabled and
the BPDUs are processed normally.
6) While logged in to switch A you see the following output:
SPANTREE-2-LOOPGUARDBLOCK: No BPDUs were received on port 3/2 in vlan 3.
Moved to loop-inconsistent state.
Which action could have caused the following output to appear on a switch?
A. The switch is configured with Loop Guard and stops receiving BPDUs.
B. The switch is configured with PortFast and starts receiving BPDUs
C. The switch is configured with Loop Guard and stops receiving superior BPDUs
D. The switch is configured with Loop Guard and starts receiving inferior BPDUs
Kevin Dorrell Thu, 11/08/2007 - 03:41
  • Green, 3000 points or more
Without knowing what level your knowledge is at, it is difficult to know at what level to pitch a response. I might go right over your head, or I might be talking down to you. Or I might not address any difficulties you are experiencing, so I would be wasting time.
I suggest that you attempt an answer to each question, explain your reasoning, and we can use that as a basis for discussion. That would help us identify any problems you are having with the subject matter.
Kevin Dorrell
Luxembourg
