Outgoing Fax calls with FXS and CCM 4.3 with H323
Nov 8th, 2007
Hello
I have a CCM4.3, and a gateway H323 with 2 BRI, 1 of them is a fax number with sg3. So the gateway h323 has a FXS port.I can receive fax calls as it says in the following link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080093fbd.shtml
but I think this document only explains about incoming fax calls. I don't know how can I set outgoing fax calls.
Any idea?
Thanks by advance
Fernando
