VPN - Site to Site - Help
Nov 8th, 2007
MY IPSEC site to site with Hub and Spoke is working great, but needs spoke to communicate with other spoke....
I have Hub and two spoke connection for my site to site VPN.
Hub private range is 192.168.1.0/24
spoke 1 private range is 192.168.2.0/24
Spoke2 private range is 192.168.3.0/24
what is requried for spoke1 to communicate with spoke2.......
Is there a cisco-sample config link for similar scenario....
Jon Marshall Thu, 11/08/2007 - 04:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Which device are you using for IPSEC at hub site and which version of software ie.
router ?
ASA
Pix - if pix which version of software.
In general answer to your question if you want go from spoke1 to spoke2 via hub you need to update crypto access-lists on the spokes and the hub to include all the networks.
But if pix or ASA device you may need additional config.
Jon
Amin Shaikh Thu, 11/08/2007 - 05:25
at Hub its a 3840 Router...
Spoke 1 its ASA
Spoke 2 its 2800 Router....
with this scenario... what is required at HUB and the spokes.....
Jon Marshall Thu, 11/08/2007 - 05:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, with a router as the hub device you should be able to do this.
Have a look at this link
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093dc8.shtml
Don't worry about it being router to router, the principle is the same.
Jon
Amin Shaikh Thu, 11/08/2007 - 06:14
Thanks....
This was exactly I needed...
at one of the SPOKE we have Remote-Access enabled as well...
REmote-Access users can access Spoke Network but cannot access HUB Network?? Can you advice what config is required to make it accessible....
Cheers
kareem.afifi Thu, 11/08/2007 - 06:16
Guys,
So far these are great. Thanks. Right now at the X location i would most likley have a 2800 series router with a PIX 515E at location X. The co-location would give me whatever equipment i would need. As of right now i have my users VPN into the network via a 3005 concentrator.
Amin Shaikh Fri, 11/09/2007 - 21:39
Cheers
