Netflow - Catalyst 6506-E
sdawson35
I am getting netflow export for my vlans on my cat 6506-E (IOS12.4), but I cannot get anything for my physical ports (Ws-x6348 blades).
Can I get netflow export for this (my CatOS Cats do) ??
Scott
7 Replies 7
Jan Nejman
Level 3
Level 3
Hello Scott,
are you using CatOS+IOS or native IOS on your 6500? If you are using CatOS on your supervisor, did you configure a netflow export on it? It is necessary to configure netflow export from both parts (switch L2 part [PFC] and routing L3 part [MSFC]). You can find information about netflow configuration for CatOS on our pages: http://netflow.caligare.com/configuration.htm
I hope that it helps...
Kind regards
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Our 2 x Cat6506-E's are native IOS, the other 2 are Cat6506's running hybrid (IOS/CatOS).
The hybrids are working fine , its the native ones we are struggling with.
Scott.
did you configure 'mls nde' on your native IOS boxes?
I recommend the following options:
mls nde sender version 7
mls aging long 128
mls aging normal 32
mls flow ip interface-full
mls nde
Here are my commands.
mls rp ip
mls aging long 64
mls aging normal 32
mls nde sender
no mls acl tcam share-global
mls ip multicast flow-stat-timer 9
mls cef error action freeze
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 172.30.2.61 9996
could you send me output of the
"show mls nde"?
Jan
Here it is.
LNPDSW01#sh mls nde
Netflow Data Export enabled
Exporting flows to 172.30.2.61 (9996)
Exporting flows from 10.172.30.1 (49515)
Version: 7
Layer2 flow creation is disabled
Layer2 flow export is disabled
Include Filter not configured
Exclude Filter not configured
Total Netflow Data Export Packets are:
6561360 packets, 0 no packets, 177159088 records
Total Netflow Data Export Send Errors:
IPWRITE_NO_FIB = 0
IPWRITE_ADJ_FAILED = 0
IPWRITE_PROCESS = 0
IPWRITE_ENQUEUE_FAILED = 0
IPWRITE_IPC_FAILED = 0
IPWRITE_OUTPUT_FAILED = 0
IPWRITE_MTU_FAILED = 0
IPWRITE_ENCAPFIX_FAILED = 0
Netflow Aggregation Disabled
it seems OK... Are your blades in the same VLAN or each blade is in another VLAN? If a traffic between blades goes throught same VLAN you cannot see that traffic unless you will configure accounting of layer2 switched vlans.
(command: ip flow ingress layer2-switched )
Jan
