LMR troubleshooting
Nov 8th, 2007
  • Silver, 250 points or more
We have a working LMR setup in a customer's lab (2811 ISR, VIC2 2e/m module connected to Polycom radio system) - we're trying to replicate it in our own lab, with somewhat different hardware: 2651XM and a VIC 2e/m)
The integration we have is based on multicast... any multicast voice sent to 239.224.0.1 port 21086 should be send to the e/m port, and likewise, any voice signal coming to the interface should be send via multicast.
Here's my current config:
Building configuration...
Current configuration : 1794 bytes
version 12.4
service config
hostname Router
boot-start-marker
boot-end-marker
logging buffered 32000 debugging
enable secret xxx
enable password nextiraone
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip multicast-routing
voice class permanent 11
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
interface Vif1
ip address 172.16.10.1 255.255.255.252
ip pim sparse-dense-mode
interface FastEthernet0/0
ip address 10.145.5.111 255.255.252.0
speed auto
full-duplex
no cdp enable
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.145.4.1
ip http server
no ip http secure-server
control-plane
voice-port 1/1/0
auto-cut-through
operation 4-wire
signal lmr
lmr e-lead voice
no comfort-noise
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-in 0
connection trunk 8611
description Funk
voice-port 1/1/1
auto-cut-through
operation 4-wire
signal lmr
lmr e-lead voice
no comfort-noise
description Funk
dial-peer voice 111 voip
destination-pattern 8611
session protocol multicast
session target ipv4:239.224.0.1:21086
codec g711ulaw
ip qos dscp cs5 media
vad aggressive
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password mypass
login
end
The thing is.. this works at the customer's, but does nothing whatsoever in the lab with the different hardware.
If I start sending audio to the multicast address, nothing happens on the router. Using "show ip mroute" I see that the router gets the multicast stream from the source, but that's it.
I get no output whatsoever when I activate debugging on the dialpeer (debug voip dialpeer all)..
since I do see the multicast (I also see the packets if I activate debugging on the interface), I'd figure that upon receiving some multicast traffic, I should see something on the dialpeer debugging, shouldn't I? Unfortunately I don't have access to the customer's system right now to see if something happens there, but this has my very confused. Plus there also doesn't seem to be anything in terms of debugging commands.
Has anybody any idea on how to track this down?
A "debug voip dialpeer all"
Anonymous (not verified) Wed, 11/14/2007 - 14:20
debug dial-peer
debug voip ccapi inout
Show vtsp call fsm
Show voice trace
These debug commands should help you out in dertmining the cause:
pcameron Thu, 01/10/2008 - 03:44
  • Cisco Employee,
You need to apply the voice class you have defined to the actual voice port being used for the LMR operation. Add the voice port command 'voice-class permanent 11'
Also try E&M type 5 operation as this more like a conventional Push to talk interface.
Here is a voice port config for a working LMR system -
voice-port 0/0/0
auto-cut-through
operation 4-wire
type 5
signal lmr
lmr e-lead voice
lmr duplex half
lmr led-on
no echo-cancel enable
no comfort-noise
timing hangover 40
connection trunk 101
Change the connection trunk number to what you are using and see if it helps.
