ccna on ubuntu
Nov 8th, 2007
Hello, this is my first posting, I have a problem where I have recently bought the icnd1 & icnd2 books for the ccna exam, problem is that the discs that come with the books wont load on ubuntu, are these discs just for windows operating system or can they be installed on linux ubuntu as well
jcrussell Thu, 11/08/2007 - 05:42
Unfortunately, I think all of the Cisco Press books CDs are for Windows. All the ones I have bought are Windows only. You might try installing WINE and running them there.
stephew Thu, 11/08/2007 - 05:52
ok, thanks for your propmt reply, i shall give it a go when i get home.
cheers
Warren
jcrussell Thu, 11/08/2007 - 09:57
"Wine is an Open Source implementation of the Windows API on top of X, OpenGL, and Unix.
Think of Wine as a compatibility layer for running Windows programs. Wine does not require Microsoft Windows, as it is a completely free alternative implementation of the Windows API consisting of 100% non-Microsoft code, however Wine can optionally use native Windows DLLs if they are available."
Copied and pasted directly from http://www.winehq.org/
stephew Fri, 11/09/2007 - 02:21
wine is an ubuntu application the runs windows executables, you can install it from synaptic
