MoH Hunt Group
Nov 8th, 2007
I have a Callamanger 4.2.1 setup and I will like to have MoH on the hunt group. I know that this is possible in IPCC, but in IPCC I cannot make the broadcast option. So I will like to know it it is possible to put some music in the hunt group in stead if ring-ring-ring.
I idee ?
/Soren
jason-calbert_2 Fri, 11/09/2007 - 07:09
  • Bronze, 100 points or more
Soren,
You could use attendant console that comes along with callmanager. With this you can broadcase a hunt group and also play MOH. This will be similar with IPCC as you will have to be logged into the applications.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed693.html
Jason
