Cisco 2500 Series - Serial Number Command
Nov 8th, 2007
All,
Is there a command for Cisco 2500s running 12.x to obtain the chassis serial number? I've been looking everywhere and can't seem to find one. I don't think the 'show version' command is a command to use for obtaining the serial number either. Will a 'show inventory' or 'show idprom' command work?
GH
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 11/09/2007 - 02:25
  • Hall of Fame,
    Founding Member
There is no command available on the 2500 to see the serial number, independently from the software version or model used.
