change Codec on call manager
Nov 8th, 2007
Our client is using CME 4.1 with ISDN E1 Pri connected to PSTN, the client bought a software to record all calls both internally and externally. When calls are done internally they are recorded perfectly, but calls to/from PSTN are recorded with a lot of noise, the software provider said that they need U-LAW codec to have a noise free recoding.
I changed the recording on ISDN interface using the Compand-Type to U-LAW, doing so degraded the whole telephony system quality.
is there is a way to convert to make U-LAW the global codec used by CME.
Thanks a lot
a.gooding Thu, 11/08/2007 - 06:53
Im not too sure if this might be the correct answer but you can change incoming call codecs via the dial-peer voice X VOIP command. and codec GXXX
i think by default its G729.
again not too sure but im sure somone with a bit more experience might be able to shed light
good luck
laithhattab Thu, 11/08/2007 - 06:55
Hi gooding
Thanks a lot for your help unfortunatley the dial peers are configured as pots and needed that way and the codec commands is not available on pots dial peers
a.gooding Fri, 11/09/2007 - 16:30
maybe the software provider should take a look from thier side?....i did a install about two years ago with CME 3.X. the recording software we used was Calrex and it still works properly. The CME was setup without any adjustments.
Note: this solution was with FXO ports though.
