quick question on SNMPv3
Nov 8th, 2007
With the authPriv user if you don't explicitly assign a OID to that user then is it a "this user can write to any table" type thing? I was just kind of curious how that worked. Thanks in advance!
Joe Clarke Thu, 11/08/2007 - 10:33
By default, the user will be read-only. You will need to assign a write view to the user before they will be able to set objects.
