GLC-LH-SM with WS-G5486
044102947
I have purchased 1 3560 switch with SFP GLC-LH-SM, i have to connect it with C4506 with GBIC WS-G5486. Can i connect them via SM cable terminated at SPF side with LC connectors and at GBIC side with SC connector. Is this possible or i need something else to do.
Thnx in advance.
kristian.lee
Afternoon,
You have it correct. The SFP has an LC connector and the GBIC has an SC connector so you therefore need a patch lead with LC and SC ends. The optics are LH so Single Fibre patch leads should be used.
Kris.
lgijssel
Level 9
Level 9
With single mode fiber you should also use an attenuator when interfaceing two devices directly. Otherwise, the receiver might become oversteered by the strong signal.
regards,
Leo
