CSA & ACS Installed together?
Nov 8th, 2007
I have the Cisco ACS agent installed on several servers. When I try to install the CSA client the installation fails. I was told this is a known problem. Does anybody know the fix for this? The only way I can get CSA to install is by uninstalling the ACS agent.
j.langton Thu, 12/13/2007 - 18:23
What changed? If this is after an upgrade, I would suspect that there is a certificate problem. Please provide more information such as version and such.
gojericho0 Fri, 12/14/2007 - 06:24
When you attempt to install CSA is there any error message in the log file?
By default you can find this at C:\Program Files\CiscoSystems\CSAgent\log\CSAgent-Install.log
tsteger1 Fri, 12/14/2007 - 11:27
I don't know much about the ACS remote client but don't they both install a service called CSAgent?
That might be why it won't work.
