upgrade IOS
Nov 8th, 2007
I have a 3560 and trying to downgrade the ios from 12.2.35.se5 to 12.2.25.seb5
gettting this error message
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support the same feature set.
I tried format flash to no avail.
jfeo Thu, 11/08/2007 - 15:21
Problem solved with the new ios 12.2(35)SE5
you need to ad this
allow-feature-upgrade
