Can Multi-Channel T1/PRI (4port) card on 7206 be hotswappable?
Nov 8th, 2007
  • Gold, 750 points or more
Hi All,
We have 7206 which has bad Multi-channel T1/PRI card with 4ports. Can this be hotswappable with new part or need to power down 7206..? Please advise.
Thank you in advance.
MS
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 11/08/2007 - 10:14
  • Hall of Fame,
    Founding Member
Yes, all PAs in 7200 router support OIR (hotswap).
mvsheik123 Thu, 11/08/2007 - 18:49
Thank you for the quick reply.
regards
MS
Wilson Samuel Thu, 11/08/2007 - 10:27
  • Community Spotlight Award,
    Mobile User, July 2015
Also most of the Cards even if the cards even if they are not hot swappable (or OIR) they can be taken out or inserted without any harm to the Router and Card.
However one should avoid any such doing.
