UM manager 6.0 business edition integration with unity connection
Nov 8th, 2007
I have tried to integrate communications manager with unity connections but i can't seem to find the users in unity connections
even though they have been created in
CM. I am also ultimately looking to integrate it with outlook/OCS so that a user can dial a contact from outlook and their phone will call the contact.
rmichelberger Mon, 12/03/2007 - 13:54
You have to assign your end user their phones at the ccm user administration (-> Primary extension!). My end user have "End User" rights.
Tommer Catlin Wed, 01/16/2008 - 08:50
You will have to check your AXL settings on Unity Connection and CUCM. This is the "glue" that holds it all together so you can import CUCM users. Rule of thumb is that they have to have Primary number/device associated to their CUCM user name.
If you are looking at calling out of Outlook your contacts, this is done through the TSP plugin.
If you are trying to use OCS, then you will need to use Presence to create the "bridge" between OCS and CUCM. OCS will send a SIP invite/request to Presence, which in turn connects to CUCM via AXL and SIP to "control" the IP device (to make the call then)
Hope this helps!
