andrew.burns Thu, 11/08/2007 - 14:15
  • Gold, 750 points or more
It looks like RSPAN appeared early 2003 on the Sup720. It's not exactly straightforward to work out, but you can do the following:
1) Check the command reference to find out which release the command first appeared in.
2) Then go to the release notes - here you'll find the dates when each release officially appeared.
Andrew.
Edison Ortiz Thu, 11/08/2007 - 14:47
  • Hall of Fame,
    Founding Member
