IEA - changing securedoc.html
Nov 8th, 2007
We just installed an IEA and want to customize the text within the securedoc.html attachment with some site specific text, logo's, link to instructions etc. Does anyone know here the securedoc.html lives (path to the file) on the IEA and is it just a simple case of writing some html code and replacing this file on the IEA ?
I assume you can't do this within the web interface ? I can't see anything obvious
jloehler_ironport Mon, 11/12/2007 - 10:00
As far as i remeber you'll find the files (.txt and .html) under /conf. Changing the envelopes isn't too complicated. Just edit the files and change the text.
The logo configuration is done via the postx gui, the logo int the bottom can't be changed.
If you try to change the registration notifications it's somewhat tricky - you have to extract some files from an archive.
Send me a PM if you need more information.
