1800 vs 2800
Answered Question
Nov 8th, 2007
Sorry to bother you with this but I couldn't find what I was looking for. As far as feature wise I see the difference between the two I was looking more hardware wise to see what the difference is. Reason being is currently I have a 2610 and I run software compression on it and at times I think that the cpu gets over runned buy the compression it as to do along with all the massive FTP and other things. At any rate I wanted to replace my 2610 with either a 1800 or 2800 but I wanted to know, hardware wise if there is a difference between the 2. Like is the processor the same or different the CPU is their a difference between the 2. Anyone know where I can find this info or let me know? Thank you in advance.
Correct Answer by Paolo Bevilacqua about 9 years 4 months ago
Missing attachment.
Lots of problem with the forum since yesterday!
Overall Rating: 4.5 (2 ratings)
wgranada1 Fri, 11/09/2007 - 06:31
Thank you sir but I've seen those already..sorry I guess I didn't explain very well I was trying to see hardware wise if there was any difference between teh 1800 and 2800 are the processors the same maybe it is in those links and I missed but anyways thanks for the suggestion about using the 2800 instead of the 1800. I'll look at those links again to see if it talks about the processor speed and cpu again.
Paolo Bevilacqua Fri, 11/09/2007 - 07:03
  • Hall of Fame,
    Founding Member
A 2801 is 20% faster than a 1841 in terms of routing performances. See attached document.
Note, cisco does not release information of the speed of the CPU used, so to know that either you do reverse engineer the box, or use Internet sources that may or may not be reliable.
wgranada1 Fri, 11/09/2007 - 07:26
Nice this is what I was looking for thank you!!!
