Missed Ping Question
Answered Question
Nov 8th, 2007
Interesting question,
I have a atack of 3548's connected by gigastack connectors. It never fails that if I power down the stack and power it back up the first ping to another switch in the stack always misses no matter which switch the ping originates.
It misses once then the replies start.
Any ideas?
Correct Answer by Jon Marshall about 9 years 3 months ago
When you power down the switches you clear the arp caches on the switches. When you power them back up and issue the ping command the first ping times out while the switch is arping out for the mac-address. Once the mac-address is entered into the arp cache it will then ping fine.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 11/08/2007 - 12:12
Jon
