Problems with outgoing calls on UC520
Nov 8th, 2007
We are currently testing a UC520-solution. Internally we can call without problems, but when we try to call out, we get a message: unknown number... .
I suppose it has something to do with the dialing plan, I am using the Cisco configuration assistant. And these settings are for a Belgian company.
The ISDN has a clip of 10 numbers, i suppose that i need to setup each phone with one of the numbers in this clip. Is this the full number with areacode?
It's hard to find, locally based specifications!
Overall Rating: 4 (1 ratings)
bwilmoth Wed, 11/14/2007 - 18:06
  • Silver, 250 points or more
enable these debugs on your gateway:
debug voip ccapi inout
debug isdn q931
debug voip dial-peer
Please provide these debugs after you make a test call from an IP Phone to the outside .
As a workaround use the forward-digits command under dial peer pointing to ISDN:
Ex:
forward-digits 10(Depending on the length of the number)
anderson-david Thu, 11/15/2007 - 03:01
  • Bronze, 100 points or more
The config assistant, as far as I know, loads in a dial plan for the USA only no matter what country you select(Cisco were looking into this), try deleting the dial peers and create your own
Dave
kosmozz_1979 Thu, 11/15/2007 - 05:49
Hi Dave,
We created our own dial-plan and it works fine. Altough we had to do some modifications in the ISDN-setup f/Belgium.
Thanks anyway,
Filip
