871 connected to a 3550 Catalyst
obmis
I am looking to create 2 VLAN's. VLAN 1 will be tunneling through a VPN to our corporate office. VLAN10 will be used for contractors to access the internet. I need help configuring the VLAN trunking, DHCP to supply to both VLAN's. I supplied my running configs minus some information. Thanks for your help.
on the router, enter this command:
sh int f0 switchport
You will see something like this
Administrative Trunking Encapsulation: dot1q
It won't show in the config because there is only one encapsulation option. If you had ISL as another option, it would be shown in the config.
Edison Ortiz
On the 3550 switchport connected to the router:
interface FastEthernetx/x
switchport trunk encap dot1q
switchport mode trunk
On the router port connected to the 3550:
switchport
On the router DHCP pool
ip dhcp excluded-address 10.10.24.254
ip dhcp pool sdm-pool2
network 10.10.24.0 255.255.255.0
domain-name [domain name for contractors]
default-router 10.10.24.254
dns-server [dns server for contractors]
netbios-name-server [ditto]
NAT for that segment
interface Vlan10
ip address 10.10.24.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
access-list 130 permit ip 10.10.24.0 0.0.0.255 any
All entries went in with out a problem. Except the command on the router port connected to the 3550. In this case I am using interface fastethernet0. Switchport mode trunk works but am unable to do the switchport trunk encap dot1q. I can put it in but it does not seem to go into the running config. I saved the config and rebooted. Do I need a different IOS to support VLAN trunking? My reseller said no. Let me know. Thanks.
Current IOS c870-advsecurityk9-mz.124-11.XJ4.bin
