LDAP Directories limit of 5
Nov 8th, 2007
in CCM 5 if I try to add more than 5 ldap directories I got the following error message: "can't add more that 5 ldap directories".
Is this a limit or is there a configuration parameter?
thanks in advance
espereir Tue, 11/13/2007 - 16:35
  • Silver, 250 points or more
Indeed there is the limitation you can't add more than 5 ldap directories.
Unfortunately at the moment there is no way to overcome this limitation.
To solve your problem, you might try mixing more than one OU in the search base
you wish to import. I am not sure this will work though.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a008063748a.html
Hope this helps!
liettig Thu, 11/29/2007 - 06:01
thanks for your reply.. can you please explain how to "mix more than one OU in search base"?..
for example I can type in search base: OU=Europe,DC=test,DC=com
how can I "mix" this with another OU?
