Memory required for DFM 3.0
Answered Question
Nov 8th, 2007
I was installing DFM 3.0 on a server and received an error message saying that there wasn't enough memory. 4096k was requested but I only had 4094k available. The installation went fine. Should I be worried about this? I have 526 devices. The server will only be used for DFM. RME and Campus are on another server. Thanks.
Correct Answer by Joe Clarke about 9 years 6 months ago
No, you will be fine. This is just a rounding error. It sounds like you have the necessary 4 GB of physical RAM. Just make sure you have at least 8 GB of swap, and DFM will work just fine on this machine.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 11/08/2007 - 19:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
