11-08-2007 02:59 PM - edited 03-03-2019 05:45 AM
Hi All;
I have a c2600 router with System image file is "flash:c2600-i-mz.123-24.bin running, i'm trying to configure subinterfaces on the device however the device doesn't give me the option to enter the encapsulation or ISL commands hence i can't configure an IP address to the sub-int any suggestion would be greatly appreciated.
11-08-2007 03:21 PM
Try this image instead c2600-bin-mz.123-24.bin
Your current image is very basic and does not have IEEE 802.1Q VLAN Support
HTH,
Edit: BTW, the image above requires 16MB flash. If your router only has 8MB flash, I'm afraid you are out of luck. I searched even on the 12.2T (when this feature was introduced) and if you want trunking support, you need 16MB flash.
11-08-2007 05:38 PM
Now days you can get 16 MEGS flash plus 64 MB DRAM to maxout your 2600 series router very cheap under $40.00 I have seen these in ebay.
