Unable to edit (add,delete mod) any of the users in CCM3.3
Answered Question
Nov 8th, 2007
Hello All,
I am having some serious trouble here with Cisco Call Manager 3.3 .....
i cant do any edits (add, delete, mod) any of the users.
The following error occurred while trying to load the requested page.
Could not delete user. UserID = "xxxx"
________________________________________________________
Error No: -2700
Error Description: Delete of User Failed
(That is all information that I have right now.)
Is it related to DC directory issue? Please advise.
Your reply is highly appreciated.
Howard
Correct Answer by Rob Huffman about 9 years 8 months ago
Hi Howard,
This is most likely related to a DC Directory issue as you correctly noted. Here is some troubleshooting info;
This error message is received when you try to add/edit users through the Cisco CallManager Administration page:
Error: The following error occurred while trying to load the requested page.
Could not update user.
Error No: -2100
Error Description: Access Denied An Access denied message appears when the DC Directory does not run completely or is in a paused state. Restart the DC Directory in order to resolve the issue. Also, look into hard drive space problems, since low hard drive space can cause the DC Directory to go into a paused state.
When a user tries to delete a user in DC Directory, this error message is received:
Could not delete user. UserID = ""
Solution
This issue can occur if the DC Directory service has been stopped. In order to resolve the issue, restart the DC Directory Server service from Start > Programs > Administrative Tools > Services. You are then able to delete the user.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008012b3c3.shtml
Hope this helps my friend!
Rob
Overall Rating: 4 (1 ratings)
Correct Answer
Rob Huffman Thu, 11/08/2007 - 21:18
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Howard,
Error No: -2100
Solution
Rob
master001 Thu, 11/08/2007 - 21:31
Thank you my friend.
I totally agree with you as I also found this "Fixing Problems with DC Directory " document!
I will test it and let you know.
BTW, I just update 7936 phone issue. It is resolved.
Take care,
Howard
master001 Wed, 11/14/2007 - 13:50
Hello Rob,
It is DC directory service issue. The DC service was stopped. After CCM publisher and subscriber server rebooted, the DC directory server service is running. And the issue resolved.
I appreciate your advice.
Howard
Rob Huffman Thu, 11/15/2007 - 05:14
  • Hall of Fame,
    Founding Member
Hi Howard,
Great work here! Nice to hear from you again :)
Take care,
Rob
