Dell 5324 layer-2 and Cisco 4948 layer-3
Nov 8th, 2007
We are changing from the DELL 6224 layer-3 to a Cisco 4948 layer-3. Are their any compatibility issues with the two devices, we will be using vlans, tagged and untagged.
glen.grant Thu, 11/08/2007 - 17:19
I'm sure the command syntax is different but you should be able to do anything that you need to do with the 4948 . If you need to look anything up just go to the main cisco.com webpage and do a search on the topic , most of the information and config data is free . They have a very extensive webpage and is the best source for answers.
